It is currently Sat May 18, 2013 4:40 am
Post new topic Reply to topic  [ 64 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Forum won't load on my iPhone?
PostPosted: Mon Apr 23, 2012 7:20 pm
Displays Backwards
Every day this week when I visit AFI, I attempt to access the forum from the main page. I keep getting an error message that there is a bad gateway? When I get home I check from my laptop, everything is fine. Che k from my phone and I have to log back in. What gives?
 Post subject: Re: Forum won't load on my iPhone?
PostPosted: Mon Apr 23, 2012 8:12 pm
Hmmmm... Not sure what that would be. It works on my iPhone. I'm typing this reply on my iPhone.
What day did that issue start for you?
PostPosted: Tue Apr 24, 2012 8:24 am
I have the same problem with my Droid.
Can get the main page, can't get to the forum. It says; "Data connectivity problem. The server failed to communicate. Try again later."
Happened each and every time I try to hit up the forums.
PostPosted: Tue Apr 24, 2012 4:18 pm
Displays Backwards
I'm on my iPhone now, but it happens each day. Usually when I get home and on my wifi, it works fine. But during the work day, and on a 3G network, it won't connect.
PostPosted: Tue Apr 24, 2012 5:35 pm
I'm also on a 3G network when I can't get in.
PostPosted: Tue Apr 24, 2012 6:35 pm
Are you guys using any sort of "shield" apps?
Or perhaps you're surfing using a proxy?
Try turning those off.
PostPosted: Wed Apr 25, 2012 8:37 am
Sorry, I don't know what those terms mean, so I probably don't know how to turn them off. :oops:
My Tech Fu is weak.
PostPosted: Wed Apr 25, 2012 5:26 pm
To turn off proxy on your iPhone:
Got to Settings.
Select "Wifi" and view the wifi list.
Click the blue arrow next to the network you're using.
Scroll down the page to see the option to turn off proxy.
PostPosted: Wed Apr 25, 2012 5:29 pm
Displays Backwards
I'm in the same boat as Shellhead, but I never had a problem before last week. I got smart today and copied what safari routes me to when I'm not on wifi and on 3G. It says:
Response Error.
Technical description:
502 Bad Gateway - Response Error, a bad response was received from another proxy server or the destination origin server.
Any idea what that means? I hate not being able to visit the forums during the day!
PostPosted: Wed Apr 25, 2012 5:31 pm
Displays Backwards
Vader, I don't see that option on my phone. Also, it only works when I'm on Wifi. It doesn't work when I'm on 3G.
PostPosted: Wed Apr 25, 2012 5:45 pm
My bad. I should have read you guys said "3G" <slaps forehead> :oops:
Quick question - are you guys using the same provider?
PostPosted: Wed Apr 25, 2012 7:37 pm
Displays Backwards
dunno about Shellhead, but I've got at&t.
PostPosted: Thu Apr 26, 2012 8:34 am
Verizon.
PostPosted: Thu Apr 26, 2012 9:03 am
I'm on AT&T - iPhone 4 and it works on both wi-fi and 3g for me.
PostPosted: Thu Apr 26, 2012 9:22 am
Same for me. No problems with mine.
