Page 1 of 1
[ 9 posts ] |
Alexander Knox
Post subject: Need some advice on a custom 40's batmobile Posted: Tue Aug 30, 2011 11:04 pm |
| HEY! New guy! GET HIM! |
I'm planning on using a Kenner Shadow Thunder Cab as a base for a 40's style batmobile. My question for the experts is what would be the best way to make the giant bat-fin that goes on the top of the car, and the bat-head that goes on the front? would sculpey or something similar do the trick? thanks! here is a pic of what I am trying to achieve. From what I have read this was an unproduced batmobile for the animated line which also used the shadow cab.
LordMudd
Post subject: Re: Need some advice on a custom 40's batmobile Posted: Wed Aug 31, 2011 3:52 am |
| Far Too Concerned with his Post Count |
Joined: Sat Feb 06, 2010 9:16 pm Posts: 4058 Location: Pasadena, Texas
For the head, I would make a sculpy model of it, make a mold, and cast it in Alumilite resin. It will be lighter and stronger. The back can be hollowed out to fit. For the fin there are many possibilities, but if you resin the head, you could resin that too, just to be consistent. Paper mache is also an option, and cheap on your budget too.
_________________ The dirty old man of figure customizing. When you enforce your point of view on an open forum, it is no longer an open forum. Museum Super Collector
JuliusMarx
Post subject: Re: Need some advice on a custom 40's batmobile Posted: Wed Aug 31, 2011 11:06 am |
| Daniel Pickett |
Joined: Sun Nov 04, 2007 6:30 pm Posts: 7930 Location: So Cal
Krypton1976
Post subject: Re: Need some advice on a custom 40's batmobile Posted: Wed Aug 31, 2011 3:50 pm |
| Killer Moth Fanatic |
Johnny Lightning made a 1:18 scale metal model version of the 40's Batmobile. Came in pieces and you had to put it together. You could probably use the pieces from it to help you with your custom. I used to have it but sold it a while back.
LordMudd
Post subject: Re: Need some advice on a custom 40's batmobile Posted: Wed Aug 31, 2011 6:37 pm |
Krypton1976 wrote: Johnny Lightning made a 1:18 scale metal model version of the 40's Batmobile. Came in pieces and you had to put it together. You could probably use the pieces from it to help you with your custom. I used to have it but sold it a while back.  Does it have room inside for a figure? CCC.
Krypton1976
Post subject: Re: Need some advice on a custom 40's batmobile Posted: Thu Sep 01, 2011 5:08 am |
LordMudd wrote: Does it have room inside for a figure?
CCC. Once the model is completed, the doors, etc., won't open. You'd have to place the figure within the cabin as you're building it and seal it inside.
LordMudd
Post subject: Re: Need some advice on a custom 40's batmobile Posted: Thu Sep 01, 2011 6:07 am |
Krypton1976 wrote: LordMudd wrote: Does it have room inside for a figure?
CCC. Once the model is completed, the doors, etc., won't open. You'd have to place the figure within the cabin as you're building it and seal it inside. and you said it is metal, which rules out customizing, unless you made molds of the unassembled model, which would mean finding one. Thanks. CCC.
An-Gel Sakura
Post subject: Re: Need some advice on a custom 40's batmobile Posted: Thu Sep 01, 2011 7:52 am |
| Mint on Card |
Joined: Fri Oct 16, 2009 10:48 am Posts: 2585 Location: Long Island N.Y. USA
Alexander Knox
Post subject: Re: Need some advice on a custom 40's batmobile Posted: Thu Sep 01, 2011 10:03 pm |
Thanks for all of the suggestions, guys. I will be sure to post pics when I finish, but it will be a little while because I haven't even bought the cab yet
Page 1 of 1
[ 9 posts ] |
Users browsing this forum: No registered users |
