It is currently Wed May 22, 2013 4:56 am
 Post subject: Jin's guide to hotgluing your action figures! Energy effects
PostPosted: Tue Feb 07, 2012 12:56 pm
Ever need to make flames, blasts, or other energy effects? Hop on over to my Hot Glue Guide and learn how. You can apply this technique to almost any action figures and I'll be adding more hotglue techniques like cannon/gunfire and others as time goes by.
"If my father were alive, I could make him proud!"
 Post subject: Re: Jin's guide to hotgluing your action figures! Energy eff
PostPosted: Fri Apr 06, 2012 10:13 am
Thats some pretty good information sir. Never considered the difference in painting low temp and high temp hot glue so that is super good to know.
PostPosted: Fri Apr 06, 2012 11:37 am
That is just fantastic Jin. Will this also work on JLU scale figures? I'm thinking it will but worried about the crummy plastic they use on a lot of them.
Also, will this work with resin-cast parts? Would love to be able to do it on certain figures...
PostPosted: Fri Apr 06, 2012 11:47 am
Hot glue will pretty much stick to anything so I dont see why It wouldn't work with regular JLU cast parts or otherwise.
This is CLIMAXone by the way just in case you didn't know, since I'm using a different name here :D than the one I use as CJ.
PostPosted: Mon May 14, 2012 4:14 pm
Will def try this technique on some customs.
http://www.cronusthebook.com/
