It is currently Fri May 24, 2013 1:47 am
 Post subject: Best way to take a DCUC figure apart at the waist?
PostPosted: Fri Nov 02, 2012 11:12 am
I'm working on a Red Hood figure. I want the top portion of Mr Terrific (waist up) and the bottom half of the Young Justice Sportsmaster.
How do I take the figure apart at the midsection? I see a few things, but I can't turn him far enough to drill.
 Post subject: Re: Best way to take a DCUC figure apart at the waist?
PostPosted: Fri Nov 02, 2012 1:39 pm
Try pulling on the two sections just slightly to get room to slide an Exacto blade in there. Carefully start your cut, then it should open up a bit more to give you more room.
PostPosted: Sun Nov 04, 2012 10:07 am
So are you saying to essentially cut the figure in half?
I mean, the turning articulation isn't that important to me, so I have no problem supergluing the figure together in the middle.
I saw a tutorial on using a dremmel and drilling, but he doesn't turn far enough.
PostPosted: Mon Nov 05, 2012 6:51 am
If you want to keep the waist articulation, then you can TRY, note I said try pulling the pelvis apart. But if you don't care, and some don't, then you can go the fast and easy route and cut him in half.
You might get in touch with Hunter Knight too. He's a DCUC / MOTUC customizer who has done LOTS of tutorials on DCUC figures. My experience is limited with them, since I specialize in JLU. He might know a better way.
PostPosted: Tue Nov 06, 2012 4:17 pm
I don't mind losing the articulation at the waist to turn him left or right...just not sure how to do it.
I'll do some more searching online for some tutorials.
PostPosted: Wed Nov 07, 2012 6:13 am
I used Buzzy Fret's tutorial over on The Fwoosh (http://thefwoosh.com/forum/viewtopic.php?f=93&t=56268) and was able to successfully crack open a figure's pelvis/remove the legs without having to dismantle the rest of the figure as well.
Joe G.
PostPosted: Wed Nov 07, 2012 6:23 am
I ended up drilling two small holes just above the figures waist when I turn him sideways and was able to crack him open enough to pull it out.
But I took an older GL and tried using Buzzy Fret's tutorial on taking the figure apart up top and I'm not having any luck at all.
I want to take a superboy wave 13's arms (shoulders too) and put it on a Young Justice Red Arrow. I'm making two Jason Todd Red Hoods. One with Sportsmaster Lower Torso and Mr Terrific Upper Body (which I already have broken clean and ready to paint). I was going to just take the arms off of superboy (not shoulders) and attach them to Young Justice Red Arrow Shoulders...but they don't fit. So I need the ability to take the whole thing off.
Problem is, I'm not sure they match on the inside and I haven't been able to crack that seem and get the upper body apart.
PostPosted: Wed Nov 07, 2012 6:24 am
PostPosted: Wed Nov 07, 2012 6:54 am
I haven't tested the upper-body crack yet, but if I do I'll let you know how it goes.
Joe G.
PostPosted: Wed Nov 07, 2012 10:02 am
Cool. I tried drilling the holes, but I couldn't get it to crack.
I still need to find another wave 13 superboy.
PostPosted: Tue Feb 12, 2013 12:43 pm
Some figures crack open better than others. I've cracked open over a dozen successfully just by following Buzzy Frets tutorial. But everynow and again I get a figure that I can't crack open without ruining a lot of the figure. Most recent ones were a Jonah Hex figure and a Mr miracle. I would drill and try to crack and it wouldn't work. I keep trying til the plastic starts to warp. This makes me try the other side, most times if one side doesn't crack the other won't. I have even tried from the top shoulder with no luck. I think it has to do with the glue strength on some figures. Its so frustrating because I end up ruining the figure. I have just learned to either not work with that particular figure or develop a work around.
Hope this helps.
