It is currently Sun May 19, 2013 8:01 pm
 Post subject: Help needed in identifying loose Batman Begins toys
PostPosted: Fri Dec 28, 2012 11:29 pm
Picked up a few prototypes from the Batman Begins line. Only problem is since the Batman figures of this line are all very similar in appearance and I can't use the paint schemes as an identifier, I'm having a hard time figuring out exactly which figures these are! If anyone here has some loose Batman Begins figures they can compare to these pictures it would help me out a lot. Thanks!
Things to note:
The pink and red torso Batman figures have 2 elbow joints but the yellow torso Batman doesn't have any articulation in his right arm.
The legs, torso front, and heads all appear to be the same. The only major differences are on the moldings on the back of the figure.
 Post subject: Re: Help needed in identifying loose Batman Begins toys
PostPosted: Fri Jan 11, 2013 6:18 am
You might have better luck with responses if you posted this in the right forum.
PostPosted: Fri Jan 11, 2013 6:38 am
MOD- Moved to Mattel-All
PostPosted: Sat Jan 12, 2013 5:01 pm
My Batman Begins figures are all put away in storage, but I can clearly identify at least one of the figures.
The one on the far right with the bent right arm is “Rapid Fire Batman” I wrote a Figure Review on BatmanYTB years ago, it’s no longer online but here are some pictures of the figure.
Rapid Fire BATMAN Batman Begins: Series 1, Asst# H1294, SKU# H1296, Mattel 2005
Blue Gray Figure with Silver Backpack, Limited Release in Last Wave of figures
It took a few tries but I got a couple of pictures of it in action
This figure was released again in Batman Begins: Series 2 Asst# H1294, SKU# H1329
All Black Figure with Gold Backpack
I’ll check on the others and see what I can turn up.
PostPosted: Sat Jan 12, 2013 5:17 pm
Roto Blade BATMAN, Batman Begins: Series 1, Mattel 2005, Asst# H1294, SKU# H1325
This figure came with Rotoblade Weapon, Wing Backpack and a Helmet so it might be your pink torso figure with the hole in the back for the Wing Backpack. I don’t have access to mine to confirm, but not many came with backpacks and I don't think it's a Deluxe Figure.
PostPosted: Sun Jan 13, 2013 10:32 pm
Hey guys, thanks for the input and thanks for moving the post to the right place!
Yes, I agree the Rapid Fire Batman is definitely the yellow one. I had an extra so I opened it up and compared the two.
On the pink torso Batman, I don't think it's the Roto Blade Batman because it has a different left arm. I don't have a loose one to compare the back but the arm is clearly a different mold. I'm thinking it may be Bomb Blast because he comes with a hang-glide type object on his back instead of a cape. But I have no loose Bomb Blast to confirm.
PostPosted: Mon Jan 14, 2013 4:58 am
That’s possible, neither Roto Blade or Bomb Blast have cloth capes. The third figure is just I regular body buck I suppose
PostPosted: Mon Jan 14, 2013 11:04 pm
Well if anyone else wants a Roto Blade prototype I found one more for sale on eBay.
http://www.ebay.com/itm/PROTOTYPE-Batma ... 56516cb07b
PostPosted: Tue Jan 15, 2013 1:49 pm
wow...the ebay seller has the same red cloth under his/her figures.
......and is also selling an 8x10 glossy of erik estrada in the batmobile.
http://www.ebay.com/itm/Erik-Estrada-In-Batmobile-8x10-Glossy-Lab-Printed-Photo-2-Unsigned-CHIPS-/261100534612?pt=Art_Photo_Images&hash=item3ccacdfb54
