It is currently Sun Jun 24, 2018 11:35 pm
Post new topic Reply to topic  [ 6 posts ]
 Post subject: Help My Joints Are Stuck
PostPosted: Wed May 15, 2013 11:38 am
Finally picked up a ToyBiz Super-Poseable "McFarlane" Spiderman, but the shin swivel is stuck. There is some small movement but it feels like I am just stressing the peg. Not sure what is going on inside but is would be nice if it could move like the other. I believe there is a locking peg that is stuck inside the housing. Anyone out there have some tips and tricks to fix up Spidey? Thanks everyone.
 Post subject: Re: Help My Joints Are Stuck
PostPosted: Wed May 15, 2013 2:39 pm
Might want to boil it.
Maybe not boil but put it in some hot water long enough for it to heat up and soften the plastic like if you were trying to do a head swap so that maybe it will loosen up the joint.
http://GeekVarietyCustoms.CustomJustice.com/
"Customizing your way"
PostPosted: Fri May 17, 2013 10:28 pm
Actually for stuck joints you want to freeze the figure. Making it warm (like with hot water) will make the plastic softer so you are more likely for the peg to tear (off). If you freeze it it makes the plastic harder. Just be gentle when trying to loosen it.
PostPosted: Sat May 18, 2013 12:03 pm
Good point. I was thinking more along the lines of glue and maybe loosening it with heat or melting it away but the cold probably makes more sense. If the cold doesn't work try heat and hopefully you can get this resolved without any breakage.
PostPosted: Mon May 20, 2013 6:50 pm
Thanks. Now does anyone have Capt. Cold's contact info?
PostPosted: Mon Feb 16, 2015 10:25 pm
How reliable would you say the freeze method is?
My wife got me the Marvel Select Venom figure for Valentnes day. I'm having problems with one of the arm peg joints not rotating where the deltoid meets the bicep. I've tried a little WD-40 on the joint to no avail, as well as the warm water soak. I was able to take a peak at the joint while it was warm and pliable and the pegs not rotating at all. Would you guys say its just an overly snug fit or is it possible that its bonded somehow? And would the deep freeze help at all, or would it just crack from the stress?
Any help welcome!
'Everybody is a book of blood; wherever we're opened, we're red.'
